brick fracture bug - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: brick fracture bug (/thread-3331.html) |
brick fracture bug - tbehrang - 09-18-2022 If I assigned multi sub material to my object then if I use brick fracture, instantly my second id will be removed in the previous version it was fine just make a box apply multi-map material to it front white back red then assing birth object to it and assign material to the particle again at the moment u add brick fracture ur other ids in the material will not be there.pls, fix this issue. tnx RE: brick fracture bug - tyFlow - 09-21-2022 There are some improvements and fixes to Brick Fracture coming to the next build...they should address the problems you mention. RE: brick fracture bug - arto.karhu - 01-09-2023 (09-21-2022, 04:01 PM)tyFlow Wrote: There are some improvements and fixes to Brick Fracture coming to the next build...they should address the problems you mention. Is there some kind of estimate, when the next build is going too be available? Just trying to decide if we can wait for the brick fracture being fixed, or do we need to go for some other route on one of our current projects. RE: brick fracture bug - tyFlow - 01-09-2023 I can't offer any estimates as to when the next build will be out, so I would move onto a workaround if you've run into this issue. |
