The particles are binding to the object, there is no speed? - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: General Discussion (https://forum.tyflow.com/forum-2.html) +--- Thread: The particles are binding to the object, there is no speed? (/thread-456.html) |
The particles are binding to the object, there is no speed? - cgdvs - 04-23-2019 The particles are binding to the object, there is no speed? RE: The particles are binding to the object, there is no speed? - mazi710 - 04-23-2019 You have no force to make anything move in the flow. You're just spawning particles and binding them to an object. All stationary. RE: The particles are binding to the object, there is no speed? - cgdvs - 04-23-2019 In fact the particles should have speed. Because it moves (the position changes, there must be speed). In nature, the position of an object changes. There are speed values. For example, we are in the car, in the macro world, we have the speed of movement. RE: The particles are binding to the object, there is no speed? - mazi710 - 04-23-2019 I don't understand what you mean but in the flow there are no force to influence the particles. No gravity, no speed, no anything. Your entire flow is "Spawn particles, make them stick to this box." You haven't defined any forces. RE: The particles are binding to the object, there is no speed? - tyFlow - 04-23-2019 Object Bind works on particle positions, not necessarily velocity depending on the bind mode. To derive velocity from position changes, add a speed operator, and set both magnitude/direction modes to "verlet". If you need continual updates, set timing to continuous. RE: The particles are binding to the object, there is no speed? - cgdvs - 04-24-2019 Thank you Tyson for your help. Your guidance is very important, I solved it. thank you very much. There are also a lot of places in TFLOW waiting for us to explore. Once again, let me deeply understand the esoteric of TFLOW. RE: The particles are binding to the object, there is no speed? - MonosP - 07-08-2019 (04-23-2019, 04:24 PM)tyFlow Wrote: Object Bind works on particle positions, not necessarily velocity depending on the bind mode. Nice, thanks for this, I'd been struggling with how to define a velocity threshold over which particles bound to an actors surface would detach and this sorted it. |
