Inferno problems with Tyflow 2.0 and 2.01 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Bugs and Issues (https://forum.tyflow.com/forum-3.html) +--- Thread: Inferno problems with Tyflow 2.0 and 2.01 (/thread-5107.html) |
Inferno problems with Tyflow 2.0 and 2.01 - [email protected] - 03-07-2026 Very slow panel performance and viewport rotation runing on 3090 card,and strange glow effect ,I m use Tyflow2.0 and 2.01 in 3dsmax2023. RE: Inferno problems with Tyflow 2.0 and 2.01 - tyFlow - 03-07-2026 Make sure your GPU drivers are up to date and that your viewport is set to Nitrous D3D 11... RE: Inferno problems with Tyflow 2.0 and 2.01 - [email protected] - 03-07-2026 (03-07-2026, 07:40 AM)tyFlow Wrote: Make sure your GPU drivers are up to date and that your viewport is set to Nitrous D3D 11... Yes ,My drive is already up to studio version 591.74,and 3dsmax viewport setting with Nitrous D3D 11,but still got same problems. RE: Inferno problems with Tyflow 2.0 and 2.01 - tyFlow - 03-07-2026 Have you enabled any system/application (3dsmax.exe) overrides in your NVidia control panel? The big round artifact looks like a texture bitdepth mismatch of some sort for the glow effect enabled in the Inferno Display operator - you can try disabling the glow in there, but that won't tell us what the actual root of the problem is... You can also try disabling progressive viewport refinement (in viewport setting, or click the 'toggle progressive refinement' button in the Inferno Display operator). |
