tyFlow v2.010 - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v2.010 (/thread-5185.html) |
tyFlow v2.010 - tyFlow - 05-25-2026 tyFlow v2.010 is up! https://pro.tyflow.com Additions: * added tyWetmap modifier * added image export to Inferno Export operator, for exporting Inferno viewport display directly to PNG with alpha and optional matte objects * Birth Inferno material conservation strength is now adjustable with a spinner * added an option in the Terrain Download operator to auto-scale downloaded terrain to real-world size in the scene * added "align to icon" option in Position Icon operator * added "flag value as already integrated" option to Spawn operator's velocity inheritance parameters * added birth order tracking option to Birth operator Fixes: * fixed a regression that could cause CUDA to crash when performing multifracture operations * fixed a regression which could cause a crash in Max 2024 only, when initializing the Birth Inferno operator * fixed a crash that could occur when changing the PhysX Shape of a particle with PhysX spline binds assigned to it * native Inferno viewport rendering will no longer display in ActiveShade viewports, so that it doesn't conflict with the results of the ActiveShade renderer (ex: Arnold ActiveShade) * fixed an issue where some operators (ex: Vertex Color) were sampling colors from texmaps using Max's color management system, instead of sampling the raw pixel values * fixed an issue that could affect the quality of the hybrid nearest-surface sample method * fixed an issue that could cause Max-wide slowdowns in scenes with 10k+ objects * increased maximum possible backtrace steps of Inferno Recall operator's upres settings to 256 * fixed an issue where the tyFlow Inferno API was returning temperature data on empty frames, if the prior frame accessed had valid temperature data RE: tyFlow v2.010 - d4rk3lf - 05-25-2026 (05-25-2026, 08:02 PM)tyFlow Wrote: tyFlow v2.010 is up! Amazing my man! Thank you so much. |
