Spawn by travel bug when using position operators
I'm attempting to create a basic particle trail, but when I use Spawn by Travel Distance, the operator seems to be calculating the particle position from the scene origin rather than its initial position (in this case, using Position Icon).  So I get these weird straight lines of particles from 0,0,0 to their starting point.  After that it works normally.
https://i.imgur.com/VLPZtc9.png
Edit: Adding just a bit to this, the mode doesn't seem to matter.  I'm getting the error whether it's by travel or per second.  I've attached my scene.
.max   spawn_bug.max (Size: 724 KB / Downloads: 458)
Just adding to this, the spawn operator works fine if I send the particles into a new event. But if I keep them in the same event it causes this problem.
Hey sorry, completely missed this post. I'll check tonight.
This will be fixed in the next build.
(04-17-2019, 05:58 PM)tyFlow Wrote: Hey sorry, completely missed this post. I'll check tonight.
Ha, no worries, I'm sure we're all keeping you busy  Big Grin
