"Element Fracture"_Random separation
HI,Tyson!
I want the "Element Fracture" node to adjust the Element to slowly transition. One element and one element are separated. I hope that there is a value that can be adjusted.
Now that the condition is met, all elements are broken down instantly.
There is also a "Face Fracture" node, which hopes to also adjust the random time of object separation and increase the test output.
Thank you for the omnipotent Tyson!
Hmm...isn't the % spinner working? That should only detach a subset of elements at time. Or do you want more control where you can actually define the exact number of elements that would detach?
Suppose there are 10 elements in each particle. Then I hope that the 10 elements in each particle can be separated by "random", "time frame" and "outside to inside". Now the node works in a way that it is instantly separated into 10 elements (particles) after satisfying the condition.
I hope that "Element Fracture" has more control. For example, when I am in some close-ups, the way the objects are separated is very important. This is just one of my thoughts. thank you
I see, yes it might be nice to have more control like that in the future.
