Odd behaviour in Surface Force using Normal?
Hi there,
I was trying to emit particles from a hemisphere geo (bottom faces deleted) using "surface force". (like speed by surface in PF)
Maybe I had the wrong settings but although the normals of the geo seem ok, and the particles seem to be generated correctly, the vectors in which they are shot outwards seem to be wrong.
I chose "Face normals" and "Accurate" sampling but still the directions are way off (even downwards).
(see attachments)
What am I missing?
Please help!
Have you set the default attraction force to 0?
(07-08-2020, 12:36 AM)tyFlow Wrote: Have you set the default attraction force to 0?
Hi, yes I did.
Maybe this is a already resolved issue...I am still on version 16082, since I did not want to change anything mid-project...
Nope...I am getting the same result in v16089.
Any thoughts?
Hmm...
Works fine here.
Attaching you file.
.rar   surface_force.rar (Size: 38.31 KB / Downloads: 305)
(07-08-2020, 10:34 AM)d4rk3lf Wrote: Hmm...
Works fine here.
Attaching you file.
Thanks you very much. In the meantime I started over with the scene and voilà ... suddenly it works. Must have been a glitch. But your help is very much appreciated, as always! Heart Smile
