How can I apply different materials?
Hello!
Particle Operator-> Shape-> Mesh Type->
I registered several objects in the reference node
VRay Instance mtl override->
Is it correct to select the Inherit from reference item?
Do I need to register another material by selecting the Scene material item?
I tried everything but it doesn't apply.
Thank you Wink
The surefire way is to have multisub material, and apply to tyflow objects.
(10-25-2019, 03:37 PM)Syu_z Wrote: The surefire way is to have multisub material, and apply to tyflow objects.
Thanks for the comment
It is possible to apply multisub mat to one reference object.
[Shapes]
New Reference node (object01) <-different multisub mat
New Reference node (object02) <-different multisub mat
New Reference node (object03) <-different multisub mat
I want to apply so
Hmm. Thanks for this tip. Now to figure out how to add different material IDs to different objects in different events. lol
just add a material id operator in each event, and type in a number of id.  Smile
http://docs.tyflow.com/tyflow_particles/...terial_id/
In my case it didn't work the way i needed it to, but i eventually figured a workaround out using" Material ID" anyways. Its a great tip still though.
[quote pid="4327" dateline="1573377536"]
[/quote]
Could you please share your workaround? I´m having the same scenario here.
(04-01-2022, 07:52 AM)Creative3d Wrote: [quote pid="4327" dateline="1573377536"]
[/quote]
Unfortunately I do not remember what this was in reference to, it was so long ago (about 3 years ago). Sorry that i can't help at the moment.
