07-15-2020, 05:27 AM
I want to do birth objects at regular intervals.
What should I do?
Currently present options are created every 1 frames
What should I do?
What should I do? Currently present options are created every 1 frames
07-15-2020, 07:18 AM
Hi!
Use the repeater option from the birth operator and set it up properly.
07-16-2020, 12:31 AM
(07-15-2020, 07:18 AM)TubeSmokeGuy Wrote: Hi! The birth has a repeater, but the birth objects do not. I want to create the shape of the moment as a particle every specific frame by referring to the character moving through the bone. birth objects do it perfectly, but you cannot set the frame interval and spacing
07-16-2020, 06:21 PM
Not sure if I understand problem.
What prevents you to use regular birth, and just use shape operator for that object? Or actors maybe?
07-17-2020, 12:22 AM
(07-16-2020, 06:21 PM)d4rk3lf Wrote: Not sure if I understand problem. https://youtu.be/ct3vWWl86f8 ok i want like this (4:07) I want to make the character's instantaneous form into particles If you can do it by 'birth', please let me know how
Here is how I would do it.
Obviously you have n animated character walking. Then - Birth object (pick a character) - voronoi fracture (let's say 25) - scale (90%) - object bind (lock to surface) - spawn (per second - 0,1 or lower) - mesh - display --------------------------------------------------spawn leads to next event - PhysX shape - PhysX collision (uncheck "geometry collision - check ground collision) - mesh - display ------------------------------------------------- PhysX collision leads to next event - Voronoi fracture (let's say 50) - mesh - display You will probably want to lower gravity settings in your Tyflow icon (under PhysX settings) ,to something like 0,2 or 0,1 --------------------------- This is all from my head, so hopefully I didn't make a mistake.
