Custom Channel Data from Bitmap
I can use a scale op to take a bitmap's gray scale values and set the scale. That is easy.
How do I take a bitmap's gray scale value and put those values in a custom channel for other purposes?  For instance: I'd like to drive the animation time of an actor with the gray scale value from a surface the particle sit upon. Could we have a way to pick a surface and texture map, grab a value and then set a custom channel value?
Or is there already a way to do this?
You can use a Surface Test operator, and just save the values by enabling the relevant option in the Test rollout.
(01-18-2021, 04:08 AM)tyFlow Wrote: You can use a Surface Test operator, and just save the values by enabling the relevant option in the Test rollout.
Yes, Surface test > Test Type Texture > Save all test values to channel.
That did it, thanks.
A
