surface birth
random birth from surface...
Birth operator + position object Smile
Position Object has an setting to delete invalid verts, so if a particle position can't be found based on your criteria within the operator, it will be deleted.
No point in a dedicated surface birth operator, when I'd just be duplicating a lot of functionality already there, and limiting the amount of control.
Unless I'm misunderstanding your request?
yeah you are right.
should i delete this thread or ?
btw how about emitting from a texture map?
Position object has a texture distribution filter as well...you can use it to emit particles on a texture on a surface.
(04-08-2019, 04:11 AM)tyFlow Wrote: Position object has a texture distribution filter as well...you can use it to emit particles on a texture on a surface.
Heart
