Rotate around axis
Hello. How to make constant particles rotation around object center? Imagine particles positioned on sphere and all this ball must rotate around sphere axis. Inherit Emitter Movement does not help. Then I try Vortex Force but particles flies into space...
Have you tried Object Bind (sticky set to 0% and mode set to surface) under your vortex Force operator? That will all particles to move but keep them stuck to the surface.
(09-14-2021, 03:12 PM)tyFlow Wrote: Have you tried Object Bind (sticky set to 0% and mode set to surface) under your vortex Force operator? That will all particles to move but keep them stuck to the surface.
Not tried - thank You.
