HI, Tyso!
Can the "open editor" of tyflow be moved to the toolbar? This will open the editor faster and more directly.
Thank you
10-07-2021, 08:01 AM
(This post was last modified: 10-07-2021, 08:36 AM by cgdvs.)
Thank you. It's really a good idea.
The only regret may need to select "tyflow" in the case.
If the tyflow object name in the scene is custom. In this case, "select $tyflow 001" is used. There will be a problem. No matter how the tyflow name changes, you can still select the tyflow object in the scene or open editing through code execution. Is this possible?
Wow, I may think this is the perfect solution!
I don't know how to describe my mood. In short, thank you very much.
