Path Follow - Pipe Radius
When using the Path Follow operator, it would be great to have something like Phoenix FD's 'Pipe Radius' option to allow users to specify a radius around a path which the particles are allowed to travel within.
An example of how this might be used: If I have an emitter with a 1m radius and wanted the particles to travel within a 1m radius but following a path. It could be something like a 'distance from path' option, possibly with independent axis controls for XYZ inputs
So you're saying to constrain particles from the path by a certain distance?
Kind of, imagine the path having a thickness rather than just being a spline. Attraction values seem allow for this but without any close control over exactly how far away from the path they are allowed to be
You could try adding an object bind, setting method to surface, friction to 0% and limiting the surface offset? Haven't tried it myself with splines but that method would work for meshes and in theory should work for splines too.
Sounds interesting, I’ll give it a go - thanks Ty
