The tyFlow BETA has come to a close. This marks the first official post-BETA tyFlow FREE/PRO build
tyFlow v1.00000
https://pro.tyflow.com
* added Select operator, for selecting particles in the viewport with a mouse, for further processing
* added tyFlex modifier, an alternative to 3ds Max's Flex modifier, with caching and multithreading
* added instance material overrides options to tyCache object
* improved speed of tyCache viewport instancing in some situations
* improved tyCache memory usage across multiple tyCache objects referencing the same cache sequence (particle meshes are now instanced across tyCache objects)
* optimized the way in which tyCache objects reload mesh files
* fixed tyCache mesh override frequency so that it won't override all cached meshes if combined frequency values are less than 100
* fixed a regression where particle mapping data wasn't passing through to generated splines correctly
* fixed a bug that could cause Alembic mesh exporter to crash
tyFlow v1.00000
