Spline Paths Neighbour proximity
Hi
I'm making a moving plexus using Spline Paths set on Neighbours. This is from help ..
Neighbors: particle neighbor proximity data will be sent to the tySplines object.
.. how can I change the distance within which a link is made?
Those settings are in the tySplines object itself.
Thank you!
(02-07-2022, 04:17 PM)tyFlow Wrote: Those settings are in the tySplines object itself.
Hi, I cant find the specific setting inside spline object, could you please share a screenshot.
Just click the tySplines object, go to the modifier panel, click on tySplines in the list and edit the 'Max dist' parameter in 'Neighbour Splines'.
