Path follow settings
Hello, I am trying to make a spinning/collapsing/wormhole animation. I am using one event with path follow, but along multiple paths. Is there a way to choose where on a path the objects are birthed from? I want them all to start at the same point. (notice that one starts way at the bottom)
I also would like to put a variable rotation along the y-axis for the particle geometry.
Thanks in advance!
.mp4   tyflow_test_02_Perspective_preview_v003.mp4 (Size: 2 MB / Downloads: 213)
Check your splines and see if that one rogue spline with particles on the bottom has its starting knot at that birth location (it'll appear as a yellow knot point in the viewport). Editable splines have options to change starting knots on a closed spline...perhaps just changing to a knot in the center will do the trick?
