Material instance wont work
Hi
I would like my particules to fade out in the end of there life instance of disappearing in 1 frame.
So I animated the opacity of the material and want to apply it with a "material instance" operator but it doesnt work,
I cant see my material when rendering (Scanline or Redshift).
If I assign the material directly to the Tyflow object it works,
but not with the "mat instance" op...why ?
(W10 + Max 2021 + RTX3090 + 128 Go)
The Instance Material operator only works with instances, so definitely won't work with Scanline and will only work with Redshift if you render as instances (Mesh operator > instances).
Ok, I set mesh op to "instances", assigned a default RS material to the Tyflow object and the rendered image is empty.
What am I doing wrong?
Did you enable the particle interface on the tyFlow object (tyFlow > interfaces > enable particle interface). Redshift requires that to be on for instance rendering.
(06-03-2022, 08:09 PM)tyFlow Wrote: Did you enable the particle interface on the tyFlow object (tyFlow > interfaces > enable particle interface). Redshift requires that to be on for instance rendering.
Ok, thanks, now it works.
