07-27-2022, 08:09 AM
Hi!
Like Object Center Out and Object Z-Axis Out it would be cool if this could work by subobject element.
So, Object Closest Element Center Out or Object Closest Element Z-Axis Out.
This means, tyFlow needs to check which is the closest element to each particle and add a speed center out velocity from that element center to those particles.
Thank you and greetings!
