cloth bind
in the cloth bind operator
In what situations is convert cloth to shape mesh used?
If you have an existing dynamic cloth simulation, and at a certain frame you want to convert it to a static mesh for use elsewhere in your flow, you would use that option.
Okay, thank you, Tyson
I thought there was no movement because it was converted to static mesh, but when I added the force operator, there was a movement
What is a static mesh?
The mesh is static but if you add a force then the particle the static mesh is attached to will move.
What is the dynamic mesh static mesh difference??
Doesn't mesh normally not move if it doesn't get force?
Dynamic mesh? I can't imagine
