04-17-2019, 08:11 PM
I was testing out the facility to have TyFlow particles as a source for PhoenixFD in the previous build (12) and noticed that the preview GPU in viewport didn't work - nothing shows. If you turn it off it switched to the old way of visualising the grid.
Does it compete for GPU resources at all?
What's really weird (although probably unconnected) is that a short while later (Max still running but not doing anything) the fans kicked into overdrive and had to reset.
(This was on a clevo laptop with a 2070 and i9)
After that the wifi adaptor wasn't working and I had to turn it off for a bit...
Like I said it probably unconnected but thought worth mentioning considering the bug fixes were quite extensive for 13.
Thanks,
Steve
Thanks,
Steve
