03-23-2024, 03:17 PM
tyFlow v1.107 is up!
https://pro.tyflow.com
* updated OpenVDB SDK to version 11, oneTBB SDK to version 2021.11
* tyConform volume/uvw mode now has options to determine which mesh (uvw or input mesh) will be relative to gizmo transform (uvw mode is now default)
* added dropdown in Object to Terrain operator to control whether generated masks will contain values representing height deltas, or areas of influence
* UVW proximity mode added to tyVertexOrder modifier
* Birth Voxels operator will now transfer tyProperties from source nodes to birthed particles
* added keyframes rollout to Find Target operator
* adding ability to export secondary UVW values as Alembic color values to Export Particles Alembic mesh options
* fixed an issue that could cause the Export Particles operator to take an exceedingly long time to export spline caches with a large number of individual splines
* fixed an issue where the tyConform modifier display in volume/uvw mode wasn't properly accounting for UDIMs
* fixed an issue where the tyParticleInterface could crash when using the Instance Node operator
* fixed an issue where using the Export Particles operator to export objects with subframe keyframes could scale all objects to zero across all frames
* fixed a regression preventing tyFlow from displaying certain debug data in the viewport
* fixed an issue in the Rotation operator where divergent axis restriction was not working if the angle step parameter value was greater than zero
* fixed an issue where meshes would sometimes be initialized with invalid explicit normals
* fixed an issue where the "closest match" mode of the tyVertexOrder modifier was always used if objects had identical vertex count
* UVW meshes extracted with a tyMesher will contain a map channel identical to the extracted UVW layout
* fixed an issue where tyFlow floating license servers were having problems activating when "backwards compatibility" mode was enabled
* fixed an issue where certain dependencies in Max would cause issues if a tyModifier which evaluates the world state of objects does so on an object while the user is in sub-object mode in the modifier panel
* fixed an issue where the tyRelax modifier's normal smoothing mode would have artifacts if tyFlow reserve thread count set to a higher value than 1
