tyFlow v1.116
tyFlow v1.116 is up!
https://pro.tyflow.com
* added Boolean operator for performing boolean operations on particles
* added detailers to tyDiffusion, for procedurally masking/detailing/inpainting regions of an image
* added shell mesh taper settings to Multifracture parameters (when in radial fracture mode)
* added "push elements" button in tyMultifracture modifier UI, for quickly adding a tyPush modifier to the stack with element mode enabled
* added optional arguments to tyDiffusion MAXScript function "tyDiffusion_loadPreset", for including/excluding parameters based on matching string (see docs for more info)
* operators with "evaluate operator after PhysX" enabled in their timing settings will be displayed with a [↓] indicator next to their name
* added Terrain Tools operator with tools for snapping scene objects to a terrain grid (and moved "print grid height info" button from Terrain Display operator to Terrain Tools operator)
* added time range mode to tyMesher (Time rollout) for sampling a mesh at multiple times and combining the result
* fixed a regression that prevents PhysX Bind operators from binding particles to the ground/world
* fixed an issue where tyDiffusion PNG metadata writer was not working properly (switching to native C++ writer)
* fixed an issue where the Birth ForestPack operator wouldn't load VRayProxy meshes properly
* fixed an issue where tyDiffusion image viewers weren't showing the source prompt in the title bar
* the retarget curve in Noise rollouts now produces more visually intuitive results for standard value ranges (-1/1)
* fixed a memory leak related to how tyFlow cleans up internally converted native meshes
* fixed an issue where PhysX center of mass changes weren't propagating to spawned children.
* fixed an issue where tyCache object/camera culling wasn't working properly if the tyCache object wasn't located at the scene origin
* fixed an issue where the Camera Cull operator wasn't properly updating at render time
