How do a soft selection
How can I create a soft selection in TyFlow? I want to apply a force gradually across a particle system. I tried using the Surface Test operator with 'Volume Inside,' but it only gives an on/off result — there's no gradual transition. Is there a way to achieve this? I imagine it might be possible through a mapping channel, but I haven't been able to find any examples.
There is maybe a better way, but you can make force gradually affect particles based on distance from the object with slow operator.
Here is I quick example I did.
https://www.youtube.com/watch?v=obz-BwGsS9U
In above example, they are born  on cylinder, and slow operator is making them soft selected based from the distance of sphere.
In the attachment is the file.
.max   Force_gradual_influence.max (Size: 740 KB / Downloads: 114)
Thank you! That's a useful technique.
