tyMeshRepair question
Hey tyFolks,
Please see attached video.
Does anyone know if it's correct procedure to add multiple tyMeshRepair modifiers??
We had to add 4 x tyMeshRepair modifiers so that it finally said 'No Issues detected', so we wondered why just 1 modifier couldn't fix the issue?
Thanks for any insight.
.mp4   3dsmax_s5wetpnVwc_1.mp4 (Size: 3.46 MB / Downloads: 259)
Mesh winding order correction has no analytical solution and is based on heuristics. These heuristics try to fix winding order with various best-estimate criteria, but given the nature of input, may fail. Since changes to winding order will change how the heuristics process the mesh, successive attempts to fix winding order on a sufficiently convoluted mesh may produce different results. In your case by chance it took 3 attempts before the heuristics deemed the mesh winding order clean.
