05-19-2019, 05:23 PM
Hey,
Sorry if this seems like an obvious thing but i cant seem to find an answer for this. I am using krakatoa and i want to fade the particles density over its age. In pflow if you set a delete operator and cache the particles, it would also save a channel called "lifespan" You could then divide the age with the lifespan to control values over the particles life. When i cache with the prt option and then load the prt in krakatoa there is no lifespan channel. Is there any way to recover that or do somthing that would give me the same result?
Thanks.
Thanks.
![Smile Smile](https://forum.tyflow.com/images/smilies/smile.png)
