So, it looks like when using a Surface Test set to "Inside Volume", when the object that is tested against the particles is animated, the animation is ignored from the Surface Test and only takes account the first frame.
Any other option, like "Outside Volume", "Distance to surface" etc are working fine when the test object is animated.
Could this be a bug, or a "feature"?
Thanks,
Greg
Edit: tested on Max2019 with v0.30
Thanks,
Greg
