[PRO v1.0121] crash rendering terrain with deadline
Thanks for this great update, so many new stuff to play with it's exciting!
I've been testing the terrain since yesterday, and I ran into a crash, while rendering with Deadline.
The simple way to test is with with the "Simple Terrain Flow" > "Peak" (for example) and rendering it with Deadline.
This is [the interesting] part of the Deadline log:
Quote:Error: FailRenderException : 3dsmax: Trapped SEH Exception in LoadFromFile(): Access Violation
Process:  C:\Program Files\Autodesk\3ds Max 2023\3dsmax.exe
Module:  C:\Program Files\Autodesk\3ds Max 2023\HLSLShaderExtension.dll
Date Modified:  11/03/2022
Exception Code:  C0000005
Read Address:  00000000
Instruction:  48 8B 10 48 8B C8 FF 52 10 4C 8B 07 48 8B 0D EA
Call Stack:
9E990000  C:\Program Files\Autodesk\3ds Max 2023\HLSLShaderExtension.dll
  +00008DEB  Exception Offset
- That's the same error for both TyFlow Pro 1.012 and 1.0121
- Same problem with AMD, Intel and GPU / No GPU render nodes
Thanks for your support!
Jo.
Hmm that's a pretty strange error.
Did the machine generate a minidump?
(02-09-2023, 05:35 AM)tyFlow Wrote: Hmm that's a pretty strange error.
No, it didn't create a minidump
(I follow this to find the dmp : https://knowledge.autodesk.com/support/3...crash.html)
More information if needed:
3ds-max 2023.3 update
Submitted via RPManager, but same errors using Vexus.
Also, I though it could be a PRO license issue, but I tried rendering (via deadline) on my machine that is currently holding the floating license, but I get the same error.
**sorry, I forgot to add that I modified the default Simple Terrain Flow.
I added a "Terrain Mesh" at the end of the stack. I guess that's the way to render it?
By the way, I'm rendering with Vray 6 Hotfix 3.
So I think this issue may be related to this issue:
https://forum.tyflow.com/thread-3492.html
I think I know what's causing it and hopefully both will be resolved in v1.013.
I had time to test the new v1.013 today, but sadly, the crash still happens with the same error message. I don't have more information about it Undecided
I'll try to run further tests and see what could be the cause.
By the way, I updated to Vray 6 Update 1, still on max 2023
Ok, I did a little more testing now and have been able to reproduce this error, including the same HLSL DLL exception.
New build will likely be posted later today...thanks for your patience.
Thank you!
v1.014 is up now, give it a shot and let me know how it goes.
