How to disintegrate/shatter an animated character?
I've been unable to figure this out. Every example I can find is a static asset, and every animated character example is always cloth stuff.
The character has a mix of mesh animation (modifier stack stuff) as well as being a skinned/rigged asset.
I've tried to birth an object referencing tyflow with tyactor/anim, object bind but it can't transfer animation unless I use a cloth bind, but the minute I use cloth bind I'm kinda locked into cloth stuff and can't really seem to break it?
If I can't do a shatter/disintegrate I can settle for a cloth destroy on this thing, but is there a way to degrade/disintegrate the cloth and have it fade out to nothing? It kinda gets shredded and just hangs around and I'm not sure how to deal with it.
Need a bit more context...is this disintegration happening in extreme closeup? Medium-long? In the distance?
There are many different ways to approach something like this, really depends on the requirements of the shot.
(04-18-2023, 12:31 AM)tyFlow Wrote: Need a bit more context...is this disintegration happening in extreme closeup? Medium-long? In the distance?
It's happening on pretty dense character meshes, not super close up, more mid shot. I figure there's probably something I'm missing but can't seem to work this out. I either get cloth on an animated mesh, or a shatter on a static frame of my mesh
How many particles are you trying to shatter this character into? Tens? Hundreds? Millions?
You can shrink cloth with a Modify Bindings operator...basically reduce the rest length of cloth binds over time.
There is also an official example scene showing how to fracture deforming geometry using the cloth-based approach.
