Send particle to another event via Zenith interaction
I want to send particles to another event based on it's contact with zenith smoke. How can i do this?
You can create regular particles out of Zenith sim if you use Inferno spawn, and in next event Inferno properties.
After you do that, there's a several ways, but you can do property (neighbors) test, for example.
(08-23-2026, 12:00 AM)d4rk3lf Wrote: You can create regular particles out of Zenith sim if you use Inferno spawn, and in next event Inferno properties.
So is there a way for an event to see the actual zenith sim, the voxel grid, and use that as a kind of surface test to send particles?
.max   zenith-test.max (Size: 812 KB / Downloads: 72)
Yes.
As I told you, you can create regular particles out of Inferno with Inferno spawn and Inferno properties, and then test it however you want.
I couldn't open your scene, because I am on older max (24), but I created you a simple scene where when particles touches smoke, they go up.
I just created particles from inferno and I used Tymesher, and used that Tymesher as a surface test for that other group of particles.
I saved scene as 2021
.max   Inferno_surface_test_.max (Size: 836 KB / Downloads: 65)
(08-27-2026, 05:24 PM)d4rk3lf Wrote: Yes.
Thank you!
