how to bind cloth to physX shape?
I want to create a crowd kite animation, the kite body is physX shape, the kite tail is cloth, how to bind those thing together?
(05-15-2019, 08:34 AM)pzstar Wrote: I want to create a crowd kite animation, the kite body is physX shape, the kite tail is cloth, how to bind those thing together?
You could use "tyFlow_balloons_001.max" in the scene files as reference. should be the same principle.
cheers!
cheers!
thanks  but the example is using 2 cloth binding together, the kite is not suitable as  cloth, i need it to be physX shape.
Cloth and PhysX do not have 2-way interaction. However, the solution is simple...don't use cloth for the string, use a PhysX Bind setup instead, with binds set to 'tether' mode. It'll act just like cloth with the right settings, and be compatible with your PhysX kite.
